Ir para o conteúdo principal
A Acer entrou no mundo dos laptops em 1997, quando comprou a divisão de PCs móveis da Texas Instruments.
1679 Perguntas Visualizar todos
The Acer Extensa 4120 laptop won't turn On
This a short description of the issue, the battery LED blinking orange for 3-6 sec then it stop blinking for 1-3 sec and changing to green for 1 sec and repeating like a loop, If I press the power button the loop stop and the battery LED change to green for 1 sec after that the loop repeat itself. I checked the power adapter, battery, battery connector and the DC power jack they all ok. Please let me know if anyone have an idea about this issue.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Try to remove the battery and unplug the power cord. Let it set for a few minutes. Then leave the battery out and plug the ac power back it and turn it on. The battery might be so dead it won't turn on. If it turns on then put the battery back in it. You may need a new battery.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you for your respond, I try this technique but it didn't work with this old machine, If the battery removed the laptop show no sign at all and no LED On or blinking. I think something else going on.
por
Adicionar a sua resposta
Luke será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 100
