Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Perguntas Visualizar todos
Screen wont come on after fixing wobbly screen!
I followed the instructions to fix wobbly screen. Everything worked well. But when I switched the macbook on, i hear it startup but the screen stays blank. Could I have knocked something? Anyone have any ideas of what I should check?
Thanks
Esta é uma boa pergunta?
Pontuação 1
4 comentários
Is just the backlight down or whole display?
por
Would you give us a link to the procedure you did?
por
The whole display is down.
So I followed this......
MacBook Pro 13" Unibody Mid 2010 LCD Replacement
....to link 16. Then tightened the loose screws and put it all back together.
por
Have you attempted to connect it to an external monitor yet? That could at least give you a starting point as to where the issue might be.
por
Adicionar um comentário
1 resposta
Solução escolhida
Go back to step #8 and reseat the display data cable, examine the connector and the slot. Make sure the little lock tab that hold it in place will throw down. Hook it up to an external monitor to verify that the GPU is putting out a signal.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
George será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 104
