Why won't my game save?
My gameboy color will play games fine, I'll save the game to continue later, when I turn it on later, there is nothing saved. Is this the game or the gameboy?
Esta é uma boa pergunta?
The problem is with the game cartridge itself. The circuit board in the cartridge has a memory battery located inside that needs to be replaced. Every battery that I have seen on the circuit boards needs to be soldered in place. Finding a new battery may be a problem however.
Good luck.
Esta resposta foi útil?
Finding a battery isn't a problem actually. EBay has plenty of sellers that have the correct battery. Search for "CR2025 gameboy battery" on eBay for the original ones and "CR1616 gameboy advance battery" for those. You'll need a soldering set and possibly a female torx bit to get into the older games or possibly a tri-wing screwdriver. Just look at the back of your game to see what you'll need to open it up.
Hi Jasmine,
The issue is not with the console, but with the game itself. Certain gameboy games, especially gameboy color games, contain save files that are reliant on a soldered-in battery within the cartridge. This means that if the battery inside the cartridge dies, the board will lose its ability to retain and overwrite a save file. Don't worry, though! This is a very common issue with these games as they are 10-30 years old, and their battery life is estimated at 5-9 years in most cases. Dead save batteries are especially prominent in games like Pokemon Gold and Pokemon Silver, due to the internal clock function these games possess. The internal clock tends to drain the battery over time. But other games are just as prone to losing their ability to save over time. There is an easy remedy to this, though. Simply replace the battery in the cartridge, and you will be able to enjoy your games again! To do this, however, you must have a soldering iron and a 3.8mm security bit (tool used to open the cartridge). The battery inside of the cartridge can be replaced in as little as three steps:
1. open the cartridge
2. desolder the battery contacts from the board (note: do not make contact between the battery and the soldering iron for obvious safety reasons)
3. install the new battery by soldering its contacts onto the board
After following these steps, just reassemble the cartridge and enjoy your game! In case you cannot find the proper CR2025 batteries and the appropriate bit, I have included a link below for the items. I, personally, have shopped from this seller and can vouch that their stuff is legit. They do take a dreadfully long time to ship, so I would shop around for a similar listing if possible. https://www.ebay.com/itm/X5-Game-Boy-GB-... Happy fixing!
You said it was a Gameboy Color game, this Narrows down details. Look on the back, if the screw is Phillips, your game is a bootleg. This means that it was produced illegally by someone trying to make profit, and instead of being a real manufactured game, someone just put a ROM dump on it. Also look at the top of the back, if it says nothing on the little bar, it is also a bootleg. Look on the front, if the label looks a bit sketchy, or the top reads "GAME" it's a bootleg.
The reason you don't want a bootleg game is because if you have one, the battery is going to be really unreliable and won't work right.
i have the same game. it is actually a dmg-01 game :)
A Truly Transformative Advantage for Startups | Accessible. Affordable. Game Changing.
From Inception to Exit. We offer services related Part-Time CFO a <a href="https://www.bostonstartupcfo.com/">Boston Startup CFO</a>, Bookkeeping, Payroll, Taxes, Early Stage Prep. We are experts. Our team members have an average of 20 years of financial leadership experience, worked in numerous startup & IPO environments, in multiple industries, and many have also started their own companies. We enable you to focus on what you do best - running and growing your business. Let us seamlessly manage the financial details. We specialize in Startups, period. We believe specialization is critical to the success of any business, and we are experts in helping you manage your fiscal matters. We provide the tools and information to help your business make the best financial decisions possible.
Its the battery that the file saves on in the cartridge i believe its a CR2025 lithium battery and you will need a 3.8mm security bit to open up the cartridge
I don’t want to have to buy a battery, but i’ll see what i can do. When i shake the cartridge (the first time wasn’t on purpose) it sounds like something is rattling around in there.
Try opening the game cartage and find a battery inside of the cartage. Then replace it then maybe the save will work.
It's the game save battery needs to be replaced
you need a new battery for the cartrage
it is the battery for the game not the game boy
me too when I downloaded the game with mod at techbigs.com, I did the same as you, but when I came back, everything was not the same as the first time I saved. and I was told by everyone, and I knew how to fix them. That is, you update to the latest version of that game, then everything will be the same as you want.
The battery in the game cartridge is died , to replace it, you will need to know how to solder to replace it
Últimas 24 horas: 6
Últimos 7 dias: 67
Últimos 30 dias: 208
Duração total: 70,255
3 comentários
thank you so much people of the web
por Cash Daigle
I am having the same problem on Mario Land 2. I have replaced it with the correct CR1616 battery, tested both contacts after installed, have confirmed it's getting the 3volts needed, yet it still is not saving. Can anyone shed some light on this? All forums explain how to replace the battery, which I have done, but it still is not saving.
Thanks you.
por Natey P
i have that same game
por DARKFIRE
