Ir para o conteúdo principal
Sony ICFC1T alarm clock/radio is manufactured so that in the event of a power outage, you have the peace of mind that your device will continue working so you never miss an event.
24 Perguntas Visualizar todos
How can I manually set the time on it?
The time the clock shows is incorrect even though I try to find my Timezone which is Vancouver, it does not show the correct time, is there any way to manually set the time?
Esta é uma boa pergunta?
Pontuação 6
8 comentários
This product even 5-6 years old right now was designed by a moron. People have to research how to set the time? I'm commenting because it doesn't automatically reset to different time zones. How do you do that? As said, by someone wonderful "who do you have to know?" Pathetic product.
por
I ran across this stupid clock in a hotel room blinking and it took me 30 mins to figure out how to set the time. What a piece of junk!!!!
por
What a piece of complicated rubbish this clock radio is
por
Why Is my comment shortened so no detail is displayed? I tried to repost it as you see but the same thing happened.
por
Anyway this clock radio is a waste of the earth’s resources as thousands will end up in the garbage bin. Not happy, Sony! Won’t buy your stuff again.
por
Exibir mais 3 comentários
Adicionar um comentário
2 respostas
Solução escolhida
Xavier Omni this should work for you"
Setting the clock for the first time
All you need to do to set the clock for the first time is select your time zone.
If you live in the Eastern Standard Time zone, you do not need to adjust the area setting.
1 Press TIME ZONE
Area number “2” appears on the display.
2 Press TIME ZONE repeatedly to select a number as follows:
Area number Time zone
0 Newfoundland Standard Time
1 Atlantic Standard Time
2 (default) Eastern Standard Time
3 Central Standard Time
4 Mountain Standard Time
5 Pacific Standard Time
6 Alaska Standard Time
7 Hawaii Standard Time
The clock display switches to the current time of selected time zone in about 4 seconds.
To change the clock setting manually, operate the unit as follows.
1 Press and hold ENTER/TIME SET for more than 2 seconds.
You will hear a beep and the last two digits of the year will start to flash on the display.
2 Press + or – repeatedly to select the year, and then press ENTER/TIME SET
3 Repeat step 2 to set the month, day and time.
After setting the time, two short beeps will sound and the seconds will start incrementing from zero.
If you do not press any button for about 1 minute while setting the clock, clock setting mode will be canceled.
You can get the users manual from here
Esta resposta foi útil?
Pontuação 19
12 comentários:
The clock is ALWAYS 8 - 10 minutes behind.
por
The clock is always 15 minutes behind, and using the instructions, cannot be set.
por
OMG. What clock needs the year, month, and date set BEFORE the time? I'm so embarrassed that I didn't fix the clock sooner. I was always confused before. Thank you!
por
My clock was not pre set and the year kept saying 2010 which was throwing off the days and the alarm. What a stupid clock
por
clock does not keep accurate time. How to fix it?
por
Exibir mais 7 comentários
It is in the manual. All the steps described by oldturkey03 are right except step 2 at the very end (manual setup). Since the enter button is not the Time Set…. IT IS THE SNOOZE/BRIGTHNESS/ENTER!!!!
Pontuação 1
2 comentários:
This is the most stupid clock I’ve ever owned
por
Runs fast and cannot be set. Waste of time Garbage
por
Adicionar a sua resposta
Xavier Omni será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 51
Últimos 30 dias: 244
Duração total: 81,220
