Pular para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
536 Perguntas Visualizar todos
Display stopped working, laptop itself works
Hi there,
I have had this Macbook around for quite a while (bought the late 2011 model as soon as it came out). Roughly two years ago, the display of my laptop stopped working completely (the backlit Apple is dead, so is the display). I never had any major display issues, this was totally out of the blue.
Thinking this was mostly a display failure issue, I brought the laptop to the Apple store I bought the laptop in. I was notified that this was not only a display issue, but it was something related to the motherboard monitor connector (I'm sorry, can't remember the exact words they said, it's been a long time) related to water damage (the laptop has been in damp environments a couple of times), and they wanted to replace monitor + motherboard for something like 600+euros or something insane like that. Being in a hurry and not wanting to invest that much money in a oldish laptop, I refused the repair and called it a day.
I tried to turn the laptop on today, because hey why not, and the display is obviously still not working, however I want to give it a try to fix it on my own.I wanted to know
: there is any way to know if the monitor is actually dead or if it could just be a connector issue? Is there any way I can check if there actually was any serious water damage? If the display was not damaged, would there be a way to fix the connection without replacing the whole motherboard?
If pictures of the inside of the laptop could help judging, I could take them .
Thanks,
Luca
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 Solução
Resposta Mais Útil
You can pop the bottom pan off to see if there is any significant water damage. The pan is only held on by ten small Phillips head screws. Omce you take the pan off, you'll see the board, and you should be able to tell if there is obvious corrosion.
The connector for the monitor you're talking about is called an LVDS connector. When you take the bottom pan off, turn the laptop around so that the battery is closest to you, and on the top right corner of the board there should be the monitor cable connecting to the board. Look specifically to see if there is any corrosion in that area. If there is, disconnect the battery, discharge the board (hold the power button down for 60 seconds with the battery disconnected), then get some high percentage isopropyl alcohol and a tooth brush to clean out the corrosion. Let it dry, and reconnect it to see if that works.
If all else fails, it's possible to see if replacing the LCD or entire lid works, but you'd have to have an extra one laying around to test it.
Let us know if you get it working again!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Luca será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 62
