Ir para o conteúdo principal
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Why doesn't the MacMini2,1 support El Captain?
Hello,
Why doesn't the Mac mini 2,1 support El Captain?
If it has 2gb of ram, 2.0ghz C2D and a 64-Bit EFI, shouldn't el captain run on this?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Bump. Still can't find out any reason why it wouldn't work.
por
Bonjour, j'ai un MacMini 2,1 qui en 10.7 je cherche une solution en 10.9, 10.10 ou 10.11 Je suis en 4Go C2D 2GHz merci à tous
por
Adicionar um comentário
1 resposta
Solução escolhida
Apple would have to write the code to do this and it isn't in their financial interest to write code for this old a machine and give it away. The whole idea is to make your machine obsolete so you have to buy a new one. Think of plastic contains like Zip Lock or Glad. They keep changing them so the tops and bottoms of older containers won't work together so you re forced to buy new ones. Why? Corporate greed ;-)
Esta resposta foi útil?
Pontuação 2
2 comentários:
Is it still possible to edit the PlatformSupport.plist file to get it to run that way?
por
Sounds like you are knowledgable enough to do it.
por
Adicionar a sua resposta
Gigabit87898 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 331
