Ir para o conteúdo principal
BLU Studio 7 II is an unlocked GSM smartphone with a 7-inch, 600 x 1024 resolution LCD display, and runs Android 5.0 Lollipop. The phablet was released in August 2015 .
50 Perguntas Visualizar todos
couldn't remember pattern, now I'm stuck in Version test
I haven't used this phone in months so don't remember sign in pattern, I used the information from internet that said to hold volume down and power button now I'm stuck in a place that has Version, Test Pass ,Test Fail, and goes through every system on the phone repeatedly. How can I get out of this and to a clean screen without the pattern?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
I got it to work. push, hold volume up & power it'll turn on other screen, use volume select factory reset and volume UP to select it.,( if you try to use power to select it won't work)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
kyl será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 132
