Ir para o conteúdo principal
Sony Xperia Z3 Compact released in Sep. 2014.
82 Perguntas Visualizar todos
What is Gps Antenna position
Where is the GPS antenna? I need to replace it, but I can't find any guide about. Is it directly welded on the motherboard?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
GPS antenna is on the plastic frame. Motherboard have a spring connector to it. :)
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hi, thanks a lot for your answer, after a bump which cracked the phone's plastic near the usb plug, the only defective functionality was the gps. I opened the phone and a tiny piece (see link for photos) fell, which I think to be the spring connector you wrote about ; would you mind, if you have informations and time, telling me where exactly is this connector initialy so that I can put it back in place ? I'd really appreciate it :)
link : https://www.dropbox.com/sc/gc30sfn44v758...
por
Adicionar a sua resposta
paolo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 613
