replace a a1212 with an A1261
hello, I have a macbook pro with the logic board a1212 broken , I would like to know if i can replace it with a A1261 (to have such a powerful pc).
thanks
Esta pergunta é pertinente?
Non-Unibody, Core Duo & Core 2 Duo Processors
thanks
No sorry they are not cross compatible , for starters the screens are different a1212 uses CFL bulb , while the a1261 uses LED bulb.
A white screen usually indicates a failed hard dive. Try disconnecting the drive from the logic board and booting from the original system installation optical disk.
Comentários:
you are right, thanks a lot!!!
por davidegatt
Then you accepted the wrong answer ;-)
por mayer
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 129
or another more powerful, as the model a1229
por davidegatt
Why do you think the logic board is broken?
por mayer
the screen remains white after power, and did not work any recovery procedure (pram reset etc.)
por davidegatt
por davidegatt
