Water Damage,What to do? Galaxy S5 ASAP PLEASE
Hello,
I need to fix a water damaged Galaxy s5. Less than 48 hours ago, someone jump into the pool with it in its pocket. In under 15 seconds, it was out of the pool and the battery was removed. I wiped it dry, than brought it home to rest on a towel. I think water got in because the charging port cover broke off and the top indicator was red. The bottom one was white. My hands were a little wet when i pulled out the battery, so that might have made the sensor trigger. I did not put it in rice, I don't think it would work. It has been laying on a towel for less than 48 hours from when it was wet. I am wondering if i have to take apart the phone to get to the logic board. I don't want to risk breaking the glass. Can I just soak the phone in 99% isopropyl alcohol? Or will anything melt? I did not try to turn it on or anything at all. I have repaired iPads before. Please help.
Update (06/27/2016)
Any help appreciated
Esta é uma boa pergunta?
2 comentários
What happens if you turned the phone on and tried to charge the phone, is it ruined? bobstalvey@gmail.com
por Robert Stalvey
Hi @Robert Stalvey,
Whether the phone is able to be retrieved after it has gotten wet and then tried to be charged etc. can only be determined after it has been properly cleaned and inspected and then tested to see if it works or what problems if any are still evident.
If a phone hasn't been cleaned properly after immersion in water and there is still water present inside the phone, components inside the phone could be irreparably damaged if you turn on the phone or try to charge it.
Water is a conductor of electricity and it provides circuit paths that were not catered for in the design of the phone. This means that components may be forced to carry more current than what they were designed to do due to a circuit path being where it shouldn't be. The first rule when any electronics get wet is to remove any power source (mains or battery) to prevent any further damage. If you cannot easily remove the battery (as is the case in a lot of phones) then do not turn it on, again to minimize the amount of power flowing through the circuits. it is bad enough as is that you cannot easily totally isolate the battery with a switch.
Also due to the impurities in water there is an electrolytic reaction with the metals in the phone which causes corrosion to occur. That is why the phones have to be opened and cleaned properly as corrosion can ruin some components in the phone
por jayeff
