Ir para o conteúdo principal
The fourth-generation Surface Pro tablet, released October 26th, 2015.
156 Perguntas Visualizar todos
Can I replace the hinge or kickstand of my Surface Pro 4
I accidentally stepped on my Surface Pro 4, and one of the hinges on the kickstand broke. Rather than replacing the entire device (I do have a warranty) I would rather try to fix it myself. The left friction hinge still works fine, but is not strong enough to hold the device alone. The kickstand itself is not cracked and would not need any replacement, only the right hinge is damaged.
Thanks.
Esta pergunta é pertinente?
Pontuação 8
Comentários:
answer is not even about the hinge, only addresses the easy answer
por
Adicionar um comentário
3 respostas
Pergunta Mais Útil
Microsoft Surface RT Kick-stand Replacement
Esta resposta foi útil?
Pontuação 2
Comentários:
answer does not address the broken hinge!
por
not a solution, it the hinge it broken it wouldnt help to put a new kick stand on
por
not any help it is not the kick stand it is the hinge. could not vote you down don't have a rep yet
por
Same comment from me, answer doesn’t address issue of broken hinge, which I also have. From what I could find you either have to tear down the product to remove the hinge or purchase a case with its own stand.
por
not helpful--hinge broken & not the stand
Pontuação 2
yeah my hinge is broken
i found this
http://www.powerbookmedic.com/Microsoft-...
Pontuação 0
Adicionar a sua resposta
Grant Smith será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 61
Duração total: 15,204
