iPad 2 Loses Reception when screen is put on
Hi
Have an ipad 2, repaired the front digitizer but every time I put the front half of the screen down it loses all reception, it works fine when the top half of the screen is not down...
I presume something is shorting out or the antenna is not correctly connecting to the case or something?
Esta é uma boa pergunta?
Is this for cellular (3G / 4G) or Wi-Fi reception?
Wi-Fi reception is the bottom antenna probably at fault.
The cellular reception are the two top antennas, one on the left side at the top and one at the right side at the top. Front camera is between both of them.
Are they cut or damaged in any way? Tearing of the antennas can cause this issue.
por Ben
