Ir para o conteúdo principal
The Tegra Note 7 is made by Nvidia and branded by graphics firm EVGA. This device is known as the EVGA Tegra Note 7 in the United States, Cherry Mobile Tegra Note 7 in the Philippines, Advent Vega Tegra Note 7 in the United Kingdom, Gigabyte Tegra Note 7 in Australia and New Zealand, Gradiente Tegra Note 7 in Brazil, Gazer Tegra Note 7 in Ukraine and Russia, and XOLO PLAY Tegra Note 7 in India.
TN7 stock battery replacement
Hello experts, the battery performance of my TN7 has gone really worse that I have to charge it at least thrice a day.I wish to switch the stock battery with a bigger one but don't have enough technical information about this. So anyone aware of this,be generous enough to share the info.By the way,thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@noufi "has gone really worse" is most likely a battery issue. In the case of your tablet replace the battery with a new one. There are no larger replacement out there. Check your setting and background apps and ensure that you run the latest OS version on it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Noufal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 1,063
