iMac doesn't turn on. No fan movement. Only LED 1 on Motherboard.
My Mid 2011 27" iMac EMC 2429 will not boot. The display doesn't come on, out of the 4 LED's on the Logic Board, only the 1st LED lights up, the other three are not.
My question is, I know it's not the PSU because the Logic board recognizes that it's getting power. Could it potentially be a failed Logic Board? and what does it cost to get it replaced?
Upon further inspection:
Removal of LCD screen. When powering on, there is some noise of noise activity from the PSU. No other activity seen or heard from other components. Upon holding the power button for 5 seconds, sequencing a hard shut down of the system; the noise level of the PSU drops from a 5 to a subtle 2. Upon further inspection of the PSU, there is an white-ish discoloration around the border of the unit. The middle of the unit, excluding the border has a glossy, almost oily presentation.
Replaced the power supply unit per advice. Nothing has changed.
Upon testing voltage of Pin 11, we have a 12.01V reading on the voltmeter.
No voltage reading from Pin 4.
Coin battery voltage measures at 3.0V.
Looking for some advice about where to go from here. As stated before, I replaced the power supply unit with a brand new PSU from iFixit and nothing changed.
Esta é uma boa pergunta?
