Ir para o conteúdo principal
iPhone 6 Lock button and Up Volume don't respond.
I dropped my iPhone 6 in the toilet a few months ago..... So I dried it off and threw it in a bag of rice. After a day I pulled it out and the volume buttons were stuck going volume down and power button wouldn't respond.
Fast foward to a few days ago I took it apart and I used rubbing alcohol on the connector and flex cable to the volume buttons and now the volume will go down just fine when I press it.. but not up. Also the lock button still doesn't work.
So what parts do I need to buy and replace? I'm unsure if I should get a new flex cable or what..
Thank you so much any help would be much appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
hi mate, for fix it, you need:
-flex cable volume
-flex cable power button
it's very easy to change it but you need to disassembla mother board. Follow the tutorial for it
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jared Gandara será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 83
