Temperatures and Amps on the core & FBDIMM's
Dear All!
After upgrading my Mac Pro 3,1 with INTEL Quad Xeon 3,2GHz processors, 32Gb of RAM, USB 3 card and an SSD as startup disc, I installed iStat Menu to check whether or not my Mac Pro was doing OK.
So far, a few points I worry about; I hope somebody out there might have a suggestion for me:
- The "AMB IC FBDIMM in Riser A Slot 1 and 2" run at 128 degrees C all the time. Isn't that too much?
- Fans stay below 800rpm almost all the time. They would boost up in case the Mac gets too hot, right?
- CPU A-core draws in about 25Amps, while B draws in about 50Amps. That's way too much, right?
I'm talking about idle mode here - no heavy lifting - although I do realise that the CPU's rarely go below 13% load.
Every help is greatly appreciated.
All the best,
Marco
Esta é uma boa pergunta?
