Fault alarm on a Xbox
I can't start my xbox because the LED turns red that means fault alarm. Help me please .Answer me as soon as you can
Update (06/16/2016)
The led in the battery and in the start button @tomchai @oldturkey03
Update (06/17/2016)
this is the image
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 3
Comentários:
We're not answering until you give us more details. It's not like we are gods who can see your console without you posting anything.
por
@agoni which LED? what do you see? what happens? You need to give us a lot more information.
por
I want to start my xbox but it doesnt. As soon as I press the start buton the led in the battery instead of turning green it turns red. The same happens with the start button.
por
Battery?
Also what is the model of your Xbox? Does the fan spin when you turn it on?
por
The model is Xbox 360 and the fan spins when I turn on but with red light
por
Mostrar mais 3 comentários
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
4 Soluções
Solução escolhida
The three red lights on the Ring of Light indicate that a General Hardware Failure error occurred. This would be a "General Hardware Failure" Try this :"Check the secondary Error Code:
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red." from here. If this did not resolve anything, it is time to either fix it yourself with these guides and parts, or have the motherboard professional reballed. Even that may only be temporary since this error is most commonly related to the Flip Chip design (long story and sure you are not that interested in it;-)
Esta resposta foi útil?
Pontuação 3
Comentários:
What does that mean
por
Resposta Mais Útil
Red light on the power brick indicates a power failure,most likely in the power supply itself.
Try replacing the power brick first.
However this is conflicting, the fan on the console should not spin when there is a power problem.
Pontuação 3
Comentários:
How can I replace the power brick @tomchai
por
You buy a new one and plug it in.
por
So I should buy a new battery charger @tomchai
por
You should try, but there is no guarantee.
por
We'll be hearing as soon as I buy a new PSU
por
Can you give the Xbox diag code? Press and hold the sync button and click the eject button 4 times, noting how many lights come on. When it flashes 4 lights, that means 0. For example 4142 means 0102
Pontuação 1
Comentários:
3444 this is the diag code
por
Are you sure? That doesn't seem to be a valid error code. When taking the diag codes, note the lights that blink really fast, not the regular flashing lights.
por
This time is 4443 @gigabit87898
por
@agoni According to xbox-experts.com, 4443 is cold solderjoint under cpu or power problem. link: https://xbox-experts.com/errorcode/E03/0...
por
The problem could be an overheating issue or that your power supply could be knackered.
So is it hot to the touch?
If so, unplug the power supply from the electrical outlet and wait a few hours.
After that's done, plug it back in and see what it does.
Pontuação 0
Comentários:
I've done that but it's the same
por
It is not hot when I touch it. I have a long time without playing with it @adriano33
por
Almost a year
por
3 leds that light up on the ring + red light on psu is mostly power related, which means that something is wrong .
Does the colour of the power led change if it's disconnected from the xbox itself?
Also try to reconnect the PSU to the comsole itself.
But if that doesn't do anything, then i'm afraid that you might need a new PSU.
por
I've tried that but it's the same
por
Adicionar a sua resposta
Agon será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 39
Últimos 30 dias: 133
Todo: 3,458
