Ir para o conteúdo principal
Uma versão atualizada do Game Boy da Nintendo com tela colorida, um pouco mais de poder de processamento e um formato menor, lançado em 1998. O reparo deste dispositivo é simples.
My Game boy game won't load
I'm having trouble with the Gameboy game not loading on my Gameboy Color. it's "Looney tunes "twouble!" ".
Imagem
this game has gave me trouble in the past but now it won't boot at all whatsoever. now all I get is the Game Boy Color logo and just "®".
Imagem
I have tested every of your game on your own and it always results with always booting or requiring a bit of coaching to get it booting
Esta é uma boa pergunta?
Pontuação 3
18 comentários
It may be that 1 of the pins on that connects to the cartridge is bent or something, look inside with a flashlight and see if anything looks amiss
por
I opened it up and it looks completely fine. Also it's only one game that doesn't work out of about 10 that I have
por
I open the game but not the game because I can't open the game cuz I don't have the right stuff
por
I meant Gameboy
por
It may just be that that game has broken... But do the same thing, look at the pis on the game and see if anything is amiss (you don't have to open it) and if everything looks fine the the only way to find out is to open the game up
por
Exibir mais 13 comentários
Adicionar um comentário
3 respostas
Solução escolhida
The suggestions by everyone is about as good as you'll get. You'll want to check the pins and give the contacts on the game a good cleaning with rubbing alcohol. If that doesn't fix the situation then one of the chips on the game PCB has probably died. The only way to check a chip (that I'm aware of) is removing it from the PCB and putting it into a tester. Other than that, you would want to inspect the traces on the PCB of the game. run a multimeter from contacts to points on the chip and such. It's a bit of work if you really want find the problem that bad.
Esta resposta foi útil?
Pontuação 5
6 comentários:
I agree with Andrew here
por
Can you give a better description on how to use the multimeter
por
To check traces, you can set your multimeter to continuity mode and touch contacts to either end. A beep or '0' on the screen will tell you there is no disruption on that trace. Checking chips is a rigorous process and extremely difficult without the correct tools.
One of the only other options you could try is reflowing the solder on the PCB using either a hairdryer (for a long time on high) or a heat gun (for short bursts) to heat up the solder and see about reconnecting any problematic spots.
Probably, in this case, a chip has failed, which would require programming to completely repair and at this point its best just to find a new game.
por
What if you CAN'T find a new game? How would you go about reprogramming it?
por
Hi Joe, I don't know how possible it would be to reprogram a GBC game chip. I know of some YouTubers that do it with NES games but as for "newer" games, I don't think it's possible. If you're still interested, look around YouTube or Google searches to see if you can reprogram a cart and go from there. Best of luck to you on that.
por
Exibir mais 1 comentário
Had the same issue of it loading game boy and nintendo but not going past the screen…all i did was blow air into the game and into the back of the game boy and BOOM it turned on YASSSSSSSS!!!!!
Pontuação 0
I don't understand why people are opening up their cartridges and cleaning up the traces, I'm sure that solves the issue, but just blow into the %#*@ cartridge's 😳. It's just like the NES, blow into the game cartridge, try again. Problem solved....
Pontuação 0
3 comentários:
@thecalamity
If you blow into it, introduces moisture which will rust eventually and screw up the cart, isopropyl alcohol completely evaporates. That's why half the old SNES carts don't work, blowing in em
por
@sarahvail
We were having the same problem with it being stuck on the logo screen. We have always blown in the games which made them work, but I was hesitant to do it this time. We did it anyway because the alcohol didn't work. Sure enough everything's working fine again! It's okay to blow in them.
por
@debbiemsj, if you open the cartridge and wipe the pins with alcohol, it will clean the dust and debris from the pins. As another measure, you can put a dab of deoxIT on the pins and rub it on the pins. It also a good idea to wipe the circuit board and components with alcohol as well. Blowing on the pins can introduce moisture to the pins and potentially development of corrosion. I believe if you cleaned the pins with alcohol and that didn't resolve your issue, but blowing on the after worked, you didn't clean them well enough.
por
Adicionar a sua resposta
Jake Donovan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 38
Últimos 30 dias: 181
Ao todo: 72,731
