Ir para o conteúdo principal
Released July 2012 by Fuhu, Inc. Model Number: NABI2-NV7A.
37 Perguntas Visualizar todos
Can't log in mommy mode
Trying to log in mommy mode, keeps saying invalid password. Password is correct. Can log into the account from my phone but can't from nabi
Esta é uma boa pergunta?
Pontuação 32
11 comentários
I push the + volume then power nothing happens. So i push - then power a reboot pops up but i can't click on anything. Then a dead Android pops up.
por
This is still an issue, right now I keep getting the "not enough space to download item, ask Dad to clear space". If I close out that message it prompts me to log into Dad mode. If I close that prompt then it goes back to the not enough space message, it's a never ending cycle that won't go away!
When I try to login, it keeps telling me I have the wrong password, it is NOT. I've tried both the nabi password that I can log into the website just fine with...and I've tried the google password associated with the email with the account. I'm 100% I'm entering both correctly. When I try to reset the password from the tablet it also will not let me, just keeps saying it can't find my info.
As of now the tablet is useless and were leaving for a 15 hour road trip tonight! This is very VERY not cool! I can't get on to see if it's actually logging into Wifi, can't get on to free space, and I've reset it numerous times and it STILL keeps telling me it's trying to download something.
Furthermore, when I do the volume up and power buttons to factory rest, it only gives me three options.... Recover, fast, and normal boot. With recovery it just goes to another screen with the android logo opened up being worked on, then it just loads normally...and STILL pops up with the %#*@ download message and STILL won't accept my password...
por
I'm having the same problem and it was right before my son's first plane ride. I bought it to keep him busy and I never packed any other toys. That was a a LONG 3 hour plane ride with a 18 month old.
por
Did you see the answer about turning off WiFi?
por
Did y’all get an answer? I am having same problem and and first plane rides for kids is Monday!!!! I need help and feel like it’s just a piece of trash now
por
Exibir mais 6 comentários
Adicionar um comentário
9 respostas
Solução escolhida
I had this problem, it appears that the Nabi servers are down (maybe permanantly?)
To enter mommy or daddy mode though, turn off the wifi - you can either do this in the settings (within the kids mode) or its easier to just put it into airplane mode (hold down the power button and there should be an option there)
Or go somewhere where there isn't any wifi
Then log in to mommy mode as normal
It would seem that if the tablet is connected to wifi, it checks the password on the internet, and seeing as there is a problem it returns an error.
I imagine though that you might not be able to change the password as currently you can't log into the Nabi account via the Nabi website.
Esta resposta foi útil?
Pontuação 25
15 comentários:
Thanks! Worked for me!
por
I forget my mommy mode password,so I can't get in.
por
Thank you! It worked
por
Worked great thank you!!!
por
Thank u it worked for us why is nabi tablets not taking the passwords it worked when we turned off the wifi
por
Exibir mais 10 comentários
Power down the nabi and wait 30 seconds and turn back on and try to log in as mommy mode. If that doesn't work then do a factor reset.
Remember doing a factor reset will wipe your nabi completely to factory new which will loss all your pictures and apps (unless you backed it up).
"Press the Volume + Button first, then press the Power Button and hold them both until the system menu appears on the upper left corner of the screen. 3. Use the Volume – Button to highlight “Wipe Data/Factory Reset,” then press the Power Button to select It. "
Pontuação 6
4 comentários:
I've tried that 3times to set the factory reset but all it sucseeds to do shut it down.
por
@rickbeau I got a answer! Turn off WiFi on kid mode and try that! Wish you best of luck!
por
It didn't work at all
por
My tab is not download any things
por
I got a solution! Turn your WiFi off on kid mode and try to sign in! Worked for me! Wish you best of luck Danielle!
Pontuação 4
3 comentários:
I can't even access my WiFi settings I'm literally locked out of my good games, all of my games on kids mode were supposed to be for my nephew.
por
I am Actually MoonWolfie just on a diffrent account,Anyone need help?
por
I keep trying to sign in and it won't work
por
I was unable reset my password and had a hard time finding out how to reset the tablet. This video is most helpful!!!
https://youtu.be/T-bamfAKvgk
Pontuação 3
2 comentários:
I like it
Thanks for making it
por
OK thanks this is so helpfulness
por
what happen im done to reset but never change the apps and i cant use it because nabi tablet need password
Pontuação 2
1 comentário:
what will i do this tablet im done to reset but never changing
por
I did the factory reset it still is asking for last Google acct which I don't know bc its second hand please help
Pontuação 2
2 comentários:
What do I do to get in to the nabi se
por
If you do a factory reset with someone else's Google account still on there the tablet will "Google Lock" meaning you can't do ANYTHING with it unless you know the other Google account info. Google Lock basically means bricked tablet. Sell it on eBay for parts or trash it.
por
i think i need a new idad
Pontuação 0
I cannot even open my settings I need help with this, I also cannot open my 3 little lines, it tells me they are open but they are
Pontuação 0
1 comentário:
I reset the tablet and I can't log in now
por
It said I need to sign in owner
Pontuação 0
Adicionar a sua resposta
Danielle será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 48
Duração total: 48,541
