Ir para o conteúdo principal
Electronic doll produced by Wicked Cool Toys in 2017. The bear is able to move its LED eyes and mouth to ‘read’ stories to children.
The tape doesn't play. It starts and stops!
I have a Teddy Ruxpin from 1983. It has worked all these years but now, the tape won't turn. It starts, then stops completely. Is there a repair shop, to fix it? It's in excellent condition.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
This video address how to fix that issue: https://www.youtube.com/watch?v=WGXhaNY7...
This one is one the drive belt: https://www.youtube.com/watch?v=vgT5l6R_...
This one is one the playback spring: https://www.youtube.com/watch?v=MgQ78PX4...
Esta resposta foi útil?
Pontuação 2
first of all he is made in 1985 by worlds of wonder. which is the version that I'm guessing you have. the problem is either a warped drive belt, a loose battery or connection problem, or most commonly, a dented pinch roller. one of them that I have is a first gen with a metal player. and that one used to have a dented pinch roller. which was causing that start and stop thing. exept mine was doing it faster, causing a blipping sound. so all you have to do is to buy another replacement pinch roller and go from there. good luck!
Pontuação 0
Adicionar a sua resposta
Patricia Hufenbecher será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 12,429
