Can't fully insert sim tray
Hello
I have a nexus 5 but the sim tray doesn't fully fit in.
The tray stops a bit before it is fully in.
Does anyone know what could cause this problem?
Thanks
Esta é uma boa pergunta?
Pontuação
2
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 651
Was this a cut sim card like from normal sim to micro sim? Because if they are not cut properly then issues like this can occur.
This may be a dumb question but make sure you're not inserting the tray upside down.
por Ben
I'm only using the tray, so no sim and it doesn't click in place.
I have tried upside down so that's not it
por Lukas Guy
Are you certain the back is snapped on all the way?
por David Spalding
Something else you might try: get an old SIM and insert the tray with it. The tray may need the added rigidity of a SIM card to slide in properly.
por David Spalding
