The main problem is that we don't have a teardown guide for it. We really need to know the exact model, that information should be on the bottom of the stand. First the logic board is probably good. Hook it up to your computer and boot up, then shine a flashlight at an angle tot he screen to see if you can discern an image. This was about the time that Apple moved over from using inverters to using an LED driver boards and LED backlight boards. One of these boards may have failed. The board may be able to be repaired or replaced. Let us know the results of the flashlight test.
I did find how to open it here:
http://perren.blogspot.com/2010/09/apple...
Even better! I found the technician guide here: http://tim.id.au/laptops/apple/displays/...
