Ir para o conteúdo principal
Apple iPad da primeira geração, disponível nas versões Wi-Fi e 3G com 16, 32 ou 64 GB de armazenamento.
266 Perguntas Visualizar todos
My Ipad's home button is no response
Hello everybody.
I brought my Ipad in US but I moved to another country now.
My Ipad have problem on the home button
Without home button means the iPad is worthless. Is there a special way to fix the iPad home button?
please help
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
4 respostas
Solução escolhida
I'm unable to find the part. This repair may void your warranty. So here's how to contact Apple in other countries:http://www.apple.com/support/contact/pho...
Here's how to replace your home button: iPad 3G Home Button Switch Replacement
Esta resposta foi útil?
Pontuação 2
1 comentário:
Detailed answer +
por
Twist the frame of your iPad gently, torque it by twisting gently at opposit corners. The makes the button work again. It was a permanent fix for me.
Pontuação 1
Turn iPad off. Add rubbing alcohol or similar solvent like CCl4 and press repetedly, i mean really, press a lot of times... These solvents are not electrically conductive so it will not corrode or short any circuit, solvents will evaporate. Hope ir helps, it helped my iPhone..
Pontuação 0
http://www.youtube.com/watch?v=yBfhCmq9V...
Here are some fixes. It says iPhone, but it works on iPad too.
Pontuação 0
Adicionar a sua resposta
caven será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 6,992
