Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Phone won't turn on and Error 4014
Hi there,
This second hand iPhone 6 I purchased is not turning on at all, and when plugged into iTunes it doesn't vibrate or show any indication of life, but then shows an Error 4014 when trying to restore. I believe the phone is in recovery mode because it will not turn on or show any sign of working.
I thought it may have something to do with the inside of the phone, so I opened it up and saw that the battery was slight swollen and smelt of chemicals (nail-polish/fruity type smell).
My question is are these two issues related, and if I get the battery repaired, should I expect to be able to repair the error 4014?
Thanks in advance
Esta pergunta é pertinente?
Pontuação 0
Comentários:
It's definitely worth a try. Battery shouldn't cost too much.
por
Adicionar um comentário
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
2 respostas
Pergunta Mais Útil
I would try replacing the battery.. but i would first unplug the battery and plug it into the wall outlet and see if there is any sighs of life.. problem could be more then a battery
Esta resposta foi útil?
Pontuação 1
Comentários:
Good idea. Will try that soon.
Thanks
por
its fixit and texted . SEE here photo after solved. this Error Solution Not Easy Remove and fix . Error 40 ,4013 , 4014 , 9 all same solution
1) fast remove nand carefully because you need sn /bt/wifi address from nand.
2) repair nand with any repair tool
3) back nand in motherbord and restore full
4) done .
this work dont this to Easy . thanks
Done Error 40 ,4013 , 4014 ,9
Pontuação 0
Adicionar a sua resposta
Zac Webb será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 832
