Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
Unit's click wheel and button is unresponsive
I have just replaced the click wheel and button, but the unit still will not respond. It will power up and sync when connected to my pc. When ejected, it wants to know which language I am using.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
make sure that the grounding pad is in place otherwise the click wheel and button might be unresponsive.
Esta resposta foi útil?
Pontuação 1
Ah, Ross, that is exactly the problem I have. Did you fix it? Crisb - what is the "grounding pad" please? Is it the blue sponge? I have tried the business card trick, but with no luck...
Pontuação 0
Adicionar a sua resposta
Ross será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 1,574
