Ir para o conteúdo principal
Designed to provide professional results in a compact package, the J1 comes in a variety of colors and lens attachments.
23 Perguntas Visualizar todos
battery compartment won't close & won't click when battery is put in
I'm not sure what the problem is but I put battery in pushing in orange battery latch and it does not latch
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
The battery pack should click into place without requiring excessive force. If it does not, be careful not to force anything as this will make things worse!
Check the following:
  • Correct orientation of battery pack: make sure the battery pack is inserted right way round. This means, in the direction of the arrow symbol and with the Nikon and arrow symbol print towards the front of the camera.
  • Foreign objects in battery compartment may interfere with correct seating of battery pack.
  • Bent or damaged contact prongs (possibly caused by one of the above) may interfere with correct seating of battery pack.
Esta resposta foi útil?
Pontuação 5
2 comentários:
byte me (12 characters plus)
por
There is a sequence THAT MUST BE FOLLOWED TO CLOSE THE BACK COVER SECURELY. STUDY THE BATTERY FACING SIDE OF THE BACK COVER CAREFULLY - PONDER FOR A MINUTE AND THE PROPER SEQUENCE WILL BE REVEALED. iTS CLOSE THE SIDES FIRST AND THEN THE TOP AND BOTTOM NEXT.
por
1 k 684 -884 yellow plastic battry clip $ 1o from amazon
Pontuação 0
Adicionar a sua resposta
Maureen McDonnell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 28
Últimos 30 dias: 115
Duração total: 9,394
