Why wont it turn on I have a red light on
my tv has a red light on it clicks but does not come on
Update (05/22/2016)
tv model is TH42PX70B it has a red light but not blinking
Esta é uma boa pergunta?
annsimpson864 your Panasonic should have a self diagnostic. Your red light should start blinking if something in those diagnostics fails. See attached blink code errors.
The only other check you can do at this time is to follow the "no Power " troubleshooting.
For more detailed information and what to check where, it will help if you post lots of images of the boards with your question. For that, use this guide. Another must-have is the proper model number of your TV.
Just double checked the attached images and the process is appropriate for your model. Start by checking it out. Disconnect the AC cable and remove the back. Without touching anything, check the power board for leaning domed or otherwise suspicious looking components (capacitors in particular)
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 242
1 comentário
It should be a blinking red light I assume.
You need to count them and then look for the count on the web.
Mine needed a small part of the motherboard replaced. good luck.
por thelittletoy89
