Ir para o conteúdo principal
Released April, 2014. CPU - Quad-core 2.3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M colors, 1080 x 1920 pixels, 5.2 inches. Internal memory - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
volume down doesn't work and the phone keep runing in safe mode
hey guys
wish you can help me
i have a sony xperia Z2 D6503 and i have i big problem with it
it always runing in safe mode and the volume down didn't work
the problem start when i replace the LCD display cause it broken
i also replace the Main Flex Cable
can you help me please
(sorry for my bad language :) )
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Either the volume rocker + power button flex cable is damaged or not mounted properly. Refer to youtube video guide link below:
https://www.youtube.com/watch?v=1jX4PWIw...
Note that the power + volume button assembly need to be placed in the housing correctly and the metal bracket needs to be put behind this and aligned properly and put in place.
You can buy the part from eBay in case you need a replacement for the Power + Volume Up / Down + Mic flex cable:
http://www.ebay.com.au/itm/FREE-SHIP-for...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
geeksalah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 1,235
