Ir para o conteúdo principal
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Perguntas Visualizar todos
Black screen after change superdrive for an SSD
Hi!
I opened my iMac 27 i7 (late 2009) and when I opened the computer I broke the backlight sync wire. No when i turn on the iMac it can boot but the display its black, and I think that I couldn't see any thing when i tried to use the flash light of my phone on the display.
If i connect an external display i can use the computer.
Does this problem with that wire cause this, or may be it's some other thing that it's wrong?
Thanks for your time guys!
Guille
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You really won't know till you replace the broken cable. Here's the part: http://www.powerbookmedic.com/xcart1/_se...
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
guillelopezgalvez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 120
