@janowski try this. First off some of the folders will be hidden so you will have to show the hidden files . You do that by
Open Folder Options by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, and then clicking Folder Options.
Click the View tab.
Under Advanced settings, click Show hidden files and folders, and then click OK.
Then go to ==>>Documents and Settings\<Username>\Local Settings\Application Data\Identities
Within that folder there should be folders starting with "{" (without the quotes)
If you have one mail identity there will only be 1 folder, if you have 2 there will be 2 folders etc.. Once you find the one with your e-mails. MOVE, Delete or Rename the Folders ".dbx" file. The next time you open OE should rebuild the folders list and the missing links. The folder will have to be resorted.
Also check on here for more info
2 comentários
I haven't used one befor but there are programs that can recover deleted item from a drive if the storage has not been overwritten but I don't know what the program is called...
P.S. When you delete something from a computer you aren't actually deleting it you just tell the computer that that area on the disc it open, if nothing has been written on top of it it should still be there Windows just doesn't know it...
Because I can't remember what the program is I didn't mark this as an answer...
por ETHREAL1
I am very grateful for your advice. Thank you very much! The issue has been resolved.)
por Janowski
