Ir para o conteúdo principal
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
1996 GMC K1500 not starting
So i had my shifter linkage replaced on a friday, on monday my truck started sputtering and lost power on the side of the road. Got it home and started farting around with it trying to figure out whats wrong. So my first attempt it started and ran for 20 minutes, but when i pressed the brake pedal it shut off. Now it will crank, but will not start. All the fuses are good, the fuel pump primes when i turn the key to on, but it won't start anymore.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Adicionar um comentário
1 resposta
Check your Neutral Safety Switch, It may not be plugged in all the way, bad, installed wrong, or damaged when the linkage was replaced.
- It's located on the drivers side of the transmission, the switch is a plastic box attached to the input shaft of the shift linkage.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
specvgini será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 131
