My replacement phone screen problems
So I recently replaced my phone screen and it works great! Except for when I actually push the screen in. Whenever I start to push the screen in to put in the bottom screws, the screen starts to change colors and eventually just completely glitch out. Without the screen fully intact, it's perfect. How can I fix this? I will add that when I had replacing it I broke the home button but I'm not sure if that would affect the screen. Also I already had to replace the flex cable, to make the screen work because I broke that too.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
Visite Nossa Loja
2 Soluções
Solução escolhida
If you put the home button bracket on backwards, it would only affect the home button. What.. What do you mean you broke the flex cable? Which one? Sounds to me like you have a faulty, or damaged display on your hands. You should be able to exchange it for a working display, from wherever you purchased it from
Esta resposta foi útil?
Pontuação 1
mon portable lg g3 il sallume et eteine tout seul
Pontuação 0
Adicionar a sua resposta
Natalie Novak será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 65
