Had a problem when I was removing the lower lcd
I follow every single step changing the lower lcd of my nintendo, but i run into one problem. In your step #6 when you remove the three battery conections, the main battery conection, which is the small white box with the red and black wire the solder broke. Do you have the small white component or can i solder it my self. Thank you
Esta é uma boa pergunta?
