Ir para o conteúdo principal
ZTE Boost MAX N9520 boasts a 5.7-inch HD IPS Display with 4G LTE and Android 4.1.
59 Perguntas Visualizar todos
person on the other end of the call can't hear me?
When I make a call I can hear the person on the other end but they cant hear me. What's wrong with my phone?
Esta é uma boa pergunta?
Pontuação 10
16 comentários
ZTE phone I can hear them they can't hear me
por
Hi Robert Everett Price,
Did you try the solution as shown in the Chosen Solution below?
por
What else could you do
por
It's only one person
por
What are you trying to say here?
por
Exibir mais 11 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Try using the earphones with the microphone attachment.
If the other people can now hear you OK and of course you can also still hear them, then there is a problem with the phone's microphone. Either it is faulty, has come loose of the systemboard or perhaps the opening at the bottom of the phone (small pinhole, behind which is the microphone), is blocked or covered over.
DO NOT stick a pin in the hole to see if it is blocked, you can damage the microphone. Use a magnifying glass to see if you can determine if there is something blocking the hole. If there is, try using a vacuum cleaner and see if it can be sucked out of the opening.
If the other people still can't hear you when using the external microphone then there is a problem with the phone's voice transmission circuitry and you will most probably have to get it professionally repaired..
Esta resposta foi útil?
Pontuação 8
10 comentários:
where is the external microphone
por
Hi @ maryhelenaopray,
A lot of mobile phones have accessories consisting of earphones which have a microphone attached to it, so that you can use the phone without having to hold on to it. If you haven't got a set like this you may have to purchase them from any phone accessory store. They aren't very expensive.
por
Why can I hear the person but the person can't hear me what is the problem
por
Hi @lovenothate
Did you try what was suggested in the Chosen Solution above, you didn't say?
por
I tried all that I'm trying to microphone I tried to earpiece I was getting here a little crackling or some other hand
por
Exibir mais 5 comentários
Adicionar a sua resposta
Selinett será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 39
Últimos 30 dias: 182
Duração total: 102,162
