Ir para o conteúdo principal
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Perguntas Visualizar todos
Pergunta encerrada
Replace secondary SSD drive...
I was wondering, on the latest iteration of the iMac 27" you have the option of getting a second SSD drive in the iMac. I was curious if you can replace this drive or add a drive in this space, or is it hard wired to the mother board.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
If you buy the latest iMac with the additional 2.5" SSD (3.5" HSS +2.5" SSD) you can replace by your own the 3.5" HDD with a 2.5 or 3.5" SSD (and the 2.5" default SSD with an other 2.5 HD as well)...
otherwise, if you buy it without the additional SSD you will still have
the extra space for a 2.5" HD (SSD or HDD as you prefer) but you will have to buy the proper support to build it in...
Does anyone know if the extra SSD space of mid 2010 27" iMAc is also in late 2009 iMacs? In other words:
I have a late 2009 iMAc and I would like to add an SSD without replacing the combo DVD... do you think it is possible?
At the moment I think I'll substitute the HD with an SSD...
Esta resposta foi útil?
Pontuação 0
It is indeed possible to add a secondary SSD to the 2010 27-inch iMac, utilizing the third inboard SATA connector which those models have. I'd suggest the following link:
http://ssd.youds.com/
The author provides suggestions on parts and presents fairly solid teardown and upgrade instructions for the 2010 27-inch iMacs. I used the above site as a reference during my own 27-inch iMac SSD upgrade and found that it is quite possible to avoid purchasing the SSD bracket for installation in the same fashion that Apple employs on build-to-order models with an additional SSD.
Unfortunately, Pietro, the 2009 27-inch models do not have the third SATA port and thus can only be upgraded by the replacement of the optical drive or main 3.5-inch hard drive, as you are considering.
Hope that helps!
Jason.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,967
