Ir para o conteúdo principal
Why does my back camera not work? I've tried replacing it.
My back camera doesn't seem to work anymore.
I've tried opening it and replacing the unit with a new one, however, it's still doing the same thing. When I open the application it's just a black screen, my front camera is working fine.
Does anyone know what's happening?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
It's completely black after a module replacement?
Have you made sure the terminal where the ribbon is plugged into is 100% clean?
Did it just turn black spontaneously and you attempted to fix it or did you recently drop / damage the phone and repair it?
There's a possibility it's a software issue..
Are you jailbroken? ;d
Esta resposta foi útil?
Pontuação 0
I've replaced the screen and the camera did stop working after that.
I probably should've mentioned it
Pontuação 0
Adicionar a sua resposta
Andryson Cher será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 86
