Ir para o conteúdo principal
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 Perguntas Visualizar todos
Why won't my iPod touch turn on?
I received an iPod Touch 5th Generation from a friend of mine. I went to turn it on and got nothing. I then charged it for about an hour and got nothing. I tried plugging it into my laptop and it didn't read it either. What is wrong and how can I fix it?
Esta é uma boa pergunta?
Pontuação 1
5 comentários:
Check the charging port for any dust or lint inside. Clean it with a toothpick or equivalent to get out the gunk. Hopefully that gets it charging.
por
It looks completely fine and the device heats up when charging, but the screen doesn't turn on and it is not read by my laptop
por
The screen may have come disconnected inside take it in for repair or if you know how open it and make sure cable is set properly
por
I think it has a bad LCD. I will bring it to get fixed today and see what an expert has to say. They did an excellent job fixing my iPad so they can probaby fix it
por
In a couple of days my iPod wouldn't turn on and can't click the home button to reboot it. My iPod wouldn't turn on and can't reboot it with the home button bc my home button doesn't work. It was back on when i had a dead battery to connect my charger.
por
Adicionar um comentário
1 resposta
Make sure button on top is set so that you do not see the orange lock color beneath then push and hold LG. Round button for up to 10 seconds it should come on if battery is charged if not I suggest taking it in for repair
Esta resposta foi útil?
Pontuação 0
3 comentários:
What do you mean by orange lock color
por
Under the switch on top one side has color (the lock) the other direction no color ( un-locked )
por
I don't have it with me so idk what you're talking about
por
Adicionar a sua resposta
Jacob Gonzalez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 200
