Ir para o conteúdo principal
Released on May 1, 2015 by LG. Can also be identified by LS770.
26 Perguntas Visualizar todos
My lg g stylo power button doesn't work
My power button doesn't work on my lg g stylo. Does anyone know how to fix it?
Esta é uma boa pergunta?
Pontuação 4
9 comentários
Did you ever solve this? I'm having the same issue.
por
I'm having the same problem
por
Lol if Albert Einstein can't fix it then nobody can XD
por
My power button on my stylo 4 isn't working
por
My button on the back of my phone don't work
por
Exibir mais 4 comentários
Adicionar um comentário
9 respostas
Pergunta mais útil
This worked for me.. take off the back case then plug in your charger. With the charger in remove the battery and put it back in. Restarted my phone. The power button is still not working but I can access it by tapping the screen. Hope this helps
Esta resposta foi útil?
Pontuação 10
10 comentários:
Thank you that worked. I had the same problem and I knew there must be a way to get it turned back on.
por
Thank you! This worked for me also!
por
WORKED!!! You're a genius! :)
por
this also worked for me
too !!
por
OMG I had the same prob,I have been trying to figure this out for weeks and it worked thank uuuu
por
Exibir mais 5 comentários
Taking off the back and taking out the battery for 15 seconds worked for me. I also noticed that the battery symbol showed it as charging, even off the charger, so that mustve been the glitch.
Pontuação 1
Try updating Android. That actually worked for me.
Pontuação 1
1 comentário:
omg this totally worked.. thank god!!!!!!
por
Mine does that too… just keep plugging and unplugging the charger in a bunch of times and it eventually turns on.
Pontuação 1
I have to actually connect the charger and then in some cases kind of press the bottom of my phone to get it to vibrate and come on and then sometimes when I take the charger out it goes blank and I can't turn it on again but it does work with a charger plugged in
Pontuação 1
I was having the same issue earlier today. Tapped the power button repeatedly about 20 times out of frustration then held it down like usual the last time & it started working again. Must be a glitch or something. Hope this helps.
Pontuação 0
I took the phone completely apart with a small screw driver and clean the contacts that lead to the power and volume buttons under the inside cover and put it back together and now it works fine.
Pontuação 0
1 comentário:
I could do this. Thanks!
por
I went to setting in the display area and and turned off the switch for the power button and then turn it back on I haven't had problems since doing it
Pontuação 0
plug in the charger and press the volume down button holding down until it comes on if that did not work try it again still not working try different combinations with charger and volume buttons that worked for me but it took a few tries for sure. hope it works for you.
Pontuação 0
Adicionar a sua resposta
tamikarose5 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 74
Duração total: 17,411
