Ir para o conteúdo principal
HD action camera with touchscreen LCD, released October 5, 2014.
Touchscreen touch works but no display
The rear touch screen/display doesn't display anything, but the touch functions still work. Is there a separate connector for the actual video display versus touch screen functions? I saw on a tear down video 2 ribbon connectors for the GoPro 4 Silver. I wonder if one of them has become disconnected.
Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi .. Did you get to the bottom of this issue as I have the same problem? thanks
Esta resposta foi útil?
Pontuação 0
2 comentários:
I wasn't able to fix it. I got the correct part but wasn't able to change it. Way beyond my expertise level.
por
Hi Matt, What was the part that you could not fit ? Thanks for the info.
por
try to reconnect the cables, it could have been jostled loose.
Pontuação 0
Adicionar a sua resposta
Matt Blankenship será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 397
