Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
183 Perguntas Ver todas
My tablet only charges while it's off.
I haven't been able to figure out the issue but I assume now it's software and not hardware. My tablet died one night while on a charging dock.
I set it to charge, then I realized that while it's on, the little charge icon shows it's charging even when it's disconnected. However, it doesn't charge at all. I tried using both the charging dock and charging port. I tried downloading 4 different apps to check the voltage, and they all say there's a charge. Additionally, they read that the battery is fine. I tried a different charger and no luck. However, if I turn off the tablet, it'll charge like normal.
I reset the tablet already. I replaced the charging port. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Solução
Resposta Mais Útil
I had this exact issue. My fix was to replace the battery with a battery from another used tablet. The device will still say that it is charging when it is unplugged at 100% but will stop shortly after. The device does charge now though.
Esta resposta foi útil?
Pontuação 1
Comentários:
Thanks so much. I will try that.
por
Adicionar a sua resposta
Celina Banuelos será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Todo: 786
