Ir para o conteúdo principal
A 14.1 MP camera released in February 2011. Now discontinued.
11 Perguntas Visualizar todos
How to change front lens
How do i change the front lens on my nikon coolpix l120
Adicionar um comentário
Kits de reparo de android
A new screen or battery is one kit away.
Comprar agora
Comprar agora
1 Resposta
I am not totally sure on this model, but ones that I have repaired in the past you might have to order the whole front lens assembly which would require you to disassemble the camera and replace the assembly or you might be able to replace just the front lens which will have an adjustment either cammed or just screw it
into place. To find that out see if the ring around the front lens is removable by either unscrewing or it may just pop out, then you can see if the front lens can be replaced easily.
You will have to call Nikon to fine out if parts are still available for this model.
Hope this info helps you out.
Add your answer
jepling will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 814
