Mac Pro 2009 won't start up - solved
Hey, everyone.
I got a problem that my mac pro 2009 doesn't start up.
Yesterday, I use it but it shutdown suddenly.
Then I press the start button again and it boot about 15 sec then shutdown.
After this, I can't start up anymore when I press the start button.
I try to check anything following this http://tim.id.au/laptops/apple/macpro/ma...
When I plug the power cord, the OVTMP CPUA and OVTMP CPUB LEDs flash red.
Press the DIAG button, the 5V STBY LED illuminates
Disconnect the front panel board and momentarily jump the SYS_PWR, no any response.
Reduce computer to minimal configuration, 5V STBY LED illuminates.
But I still don't know which part broken.
Can anyone help me or tell me which part I can check?
Whether the OVTMP CPU A, B LEDs, and 5V STBY LED illuminating means the power supply and backplane board is ok?
Thanks a lot.
Esta é uma boa pergunta?
Did you solve this problem? I'm having the exact same problem!
por Lucas Saldanha
yes!! I solved my problem. Finally, I can sure that my backplane board is out of work , so I replaced it ,and my mac work again.
por Hong Wei Li
Thanks! I'll try to do the same!
por Lucas Saldanha
Hi, I am facing the same problem now. May I know what is backplane board? Is it the logic board?
por burtt.mackintosh
Yes, it's the logic board.
por Hong Wei Li
Exibir mais 2 comentários
