Ir para o conteúdo principal
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110 Perguntas Visualizar todos
Phone won't turn ON or Charge.
Hey there Ifixit Community, i came to you because i think my phone done a short circuit, it was ON and pluged in an inactive USB port on my PC which i've plugged internaly just after.
Then i noticed that the low battery LED on the OnePlus doesn't blink anymore. First of all i thought about a complete discharge. But no charging LED. I've plugged the phone on the power adapter : No LED. This is when i started to freak out.
I've took appart the phone, removed the battery, mesured the voltage : 3.77 Volts. The battery is normaly 4.35 Volts.
Is it a big gap even if there is always a tolerance ?
Is my battery is dead ? Or something shorten the motherboard ?
I don't want to buy a new battery if this won't solve the issue, and i have no schematics to do a continious testing with my multimeter on the motherboard..
Any help is welcommed. Thanks.
Update (06/20/2016)
Is changing the battery will solve the charging, and the fact that my phone does not get detected by my PC ?
Update (06/27/2016)
If anyone got any ideas, like i don't know, a motherboard diagram or something that can help me fix this problem... Otherwise my last thing to do sill be to sell this phone for part and buy a new one. I've seen motherboard on ebay at 200$..
Esta pergunta é pertinente?
Pontuação 7
13 comentários
up please, i'm kinda lost right now...
por
I have the same problem!
por
My OnePlus 3T turned off and it wouldn't turn on again or charge. The trick that did it for me was to remove the sim card, turned it on, then put the sim card back. Hope it helps
por
Keep your mobile for charging for 24 hr even it show no response then unplug and keep for atleast 12 hr test.then plug Charger to mobile ..may b at this it show low battery icon charging but if not then do this..:
1} Press power button for 30 SEC.
2}volume down button +power button for 20sec.
3) Still not show response then repeat whole process wih patience... Or u need to replace battery.
por
I had this problem (phone froze during normal use then powered off) and it turned on again as soon as I removed the sim card. This is the easiest thing to try first!
por
Mostrar mais 8 comentários
Adicionar um comentário
9 respostas
Solução escolhida
try to replace the battery it will help. I have the same issue i don't know how to solve it so i tear it down so i find out the battery is molded so i 'm replacing now
if any thing is works pls tall me
Esta resposta foi útil?
Pontuação 1
2 comentários:
try taking out the SIM card and rebooting first
por
LI-batteries can be charged about 500 to 1000 times depending on a bunch of stuff. I have a few One Plus One batteries if you can't find one.
bmaz121 at Gmail. Careful because the battery is glued to the frame, see the YouTube video on a screen replacement to see how to get it out.
por
Pergunta Mais Útil
Hey Guys !! I had problems starting up my 1+1 phone .First thght it had low charge and thus charged it for whole night .But still my phone will not come up. Finally figured out that if you press the power button + Volume down key for a minutes or so then you get a list of options .you need to select the first option to "reboot the phone"
Pontuação 16
14 comentários:
Thanks. This method works on my phone.
por
Worked like a charm !!
por
worked like a charm
por
Loads of thanks! You saved my ass.
por
Worked. Thanks! I was really concerned.
por
Mostrar mais 9 comentários
Hi, guys! I had a similar issue: my oneplus was on around 15% when it just switched off. I put it on charge overnight but in the morning it did not turn on at all no matter how long i was pressing the power button.
I went on some forums and saw ppl recommending to leave the phone on charge for 12h and try again - did not work. power button + volume down also did not work, nor did taking out my sim card.
When i pressed volume up + power though i saw a quick message on the screen that the battery was too low on charge (below 1 per cent). I then tried another piece of advice and put my phone on a charge via laptop - and it worked!
I charged it enough to turn it on and then transferred it to charge from a power socket - works now
Uiii, i dont have to go to the repair shop
Hope it will help someone ^^
Pontuação 1
One thing is sure, it's not the USB Connector, bought a new one, changed it, still the same...
Phone charge while off, but when it's ON, I've the logo on the status bar, the LED shows up. But when i go in settings -> Battery, under the graph it says "Not Charging".
Pontuação 0
1 dos comentários:
Open up the phone and be sure the USB connector to the mainboard is snapped on correctly. I read replacing the battery if you see any bumps on it. I replaced the charge port, $5, and battery and now OK. If not buy a used phone and swap out the mainboard $40. You'll have to give the carrier the new IME number if so.
por
I replace the battery but it solved not the problem.
Pontuação 0
Hi Thomas
i think it is better you can go to a local repaire service guy to identify the root caused: Battery issue/power IC issue/CPU Issue/USB Board.
1. battery issue, it is easy to replace with a battery and fixed it.
2. if it is concern to motherboard, i think it is not easy for you identify it, it maybe need replace with a motherboard.
3. if it is USB Board issue, it will be easy to buy a USB Board.
Thanks
Jack.
Pontuação 0
Hi
My 1+1 was dead the whole night. any idea how long does it take to charge. no led light while charging. phone is not responding to power on button. i even tried holding power button and volume down button . no response. probably it is been charging for more than half an hour now. help please
Pontuação 0
2 comentários:
Hi, i had the same problem today. The volume down + power button did not work. So I put the phone in fast boot mode (volume up + power button) and then switched it off and tried turning it on again. and wola! it turned on. Dunno how it makes sense but its on right now. This happened like 30 mins back.
por
I fkn love u Kallol, pm me ur number and ill give u a free bj
por
Sometimes on a dead phone you have to hold the power button for a long time. Mine would vibrate but not turn on. but after a USB port and Battery change it worked. If you don’t feel the vibrate from the power button hold then you may have a broken power button $2.50. You can send me the phone and I will try to revive it. $50 not including parts.
It’s a great phone and worth it if your strapped for cash.
Pontuação 0
I had the same symptoms on my phone, wouldn’t go past 50%, wouldn’t really show it’s discharging. I would reset it a million times, and sometimes while powered up I would get in and it would go back to normal. Oddly enough I noticed that when i would set my phone down, it would revert back to the 50% and the LED charging light would turn off again. So… I wondered, hmm maybe it is the USB port, i forced the charger pin inside the port down a bit, hooked up the cable and pull it down a bit (my cable isn’t in top notch shape but it works). AAAnnnndddd VOILA,,,, charging LED turned on, and the battery went back to normal and it would say charging again, fiddling with the cable a bit or pulling it in the wrong direction and boom the light would turn off and we’re back to zero. So, in my case, it is a damaged port, I mean the phone is well over 5 years old now and it’s still going.
My solution, really pull down on the pin and it’s been working for a day now again. I ordered a replacement usb port and a battery just in case, but those things take time to get to me (1-2 months). For now it’s fine, I do have a oneplus 7 pro i bought recently as my main phone now, but I’m determined to restore my OPO back to normal with those fixes.
Pontuação 0
Adicionar a sua resposta
Thomas Dangest será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 66
Últimos 30 dias: 375
Duração total: 71,615
