Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
Replace screen of iPhone SE with a screen for iPhone 5s?
Hi,
I see on iFixit that the screen is the same between iPhone 5S and iPhone SE.
I am looking to replace my screen but I find no seller for "iPhone SE screen".
So I bought a screen for iPhone 5S on a merchant site. Will it be compatible? Or not necessarily ?
Thanks in advance !
Esta é uma boa pergunta?
Pontuação 2
1 comentário
This guide suggests that the iPhone 5S part is not compatible with the SE. So now I am confused: https://eustore.ifixit.com/en/Parts/iPho...
por
Adicionar um comentário
6 respostas
Solução escolhida
Completely interchangeable. However don't forget to transfer the original home button over.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Have you yourself successfully changed the screens or are you saying this based on what you have read/seen online?
por
I have tried three 5S screens from different suppliers on the SE and they all had display issues, Lines of pixelated. Tested all screens on a 5S and they were perfect......
Pontuação 3
2 comentários:
same version of iOS?
por
I have also observed this .... Tried all 6x 5S aftermarket screens I had available and got lines , glitches etc even though the display and touch functioned without an issue.
These same screens in a 5S work perfectly
My supplier has just sold me what they referred to as a "refurbished original" a screen so I am going to try that! Will update here when I have fitted it.
por
You pretty much have to use oem parts for the 5s parts to be interchangeable.
Otherwise the refurbished ones out there tend to make the screen shaky and give off all sorts of graphical glitches.
Pontuação 3
1 comentário:
Thankyou this has answered my question i was getting all sorts of issues
por
I have read that they have the same display, you can buy a iPhone 5S display and put this on iPhone SE.
Pontuação 1
they can share the same LCD screen except the home button, i found this iphone se lcd screen http://www.etradesupply.com/apple-iphone...
Pontuação 0
I have changed displays on iphone SE. Copy screens had all kinds of errors, interlaced picture, colors are bleeding out from app icons and moving around alittle.
Original 5S screen worked fine, but now 2 days afterwards a customer contacted me that the lighting is off, and sometimes the touch stops working. So she will be back this monday.
Odd thing tough, when I removed the broken screen, there were no Apple logo on the flex cabels connecting the lcd&touch to the mainboard in the phone. instead there were 4 dots in a squared form.
looked like a copy screen basicly.
Pontuação 0
1 comentário:
I also tried a few different 5s screens and while the touch worked fine they all had severe problems with the display.
por
Adicionar a sua resposta
Kalorte será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 4,414
