Ir para o conteúdo principal
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
83 Perguntas Visualizar todos
A1267, MB382LL/A everything but lcd backlight working
I just got a used 24" LED Cinema Display. Everything works except for the LED backlight. By everything, I mean the sound, USB, camera, the LCD display...
I can shine a flashlight on the screen and see the display working, but there's no backlight.
i've checked and re-seated all cables, and I can't find anything fishy other than this VR. it seems to be a little brown around the solders, and the plastic protector on the back of the logic board has melted a bit directly beneath it. the regulator is the center one.
i've run through the apple troubleshooting flowchart, but i don't know where TP81 (test point) is.
thanks in advance
Esta é uma boa pergunta?
Pontuação 0
1 comentário
ok, i found the diagram and tested the correct voltage at every point. i ran through both the BLANK/NO VIDEO and DEAD/NO POWER flowcharts, and everything tested ok. at this point, i'll have to assume i've got a bad function cable, or bad LED backlight?
por
Adicionar um comentário
1 resposta
Solução escolhida
eBay logic board $92.99
all is well
Esta resposta foi útil?
Pontuação 0
2 comentários:
Hey - I've got a similar problem - just wonder if the logic board fixes the backlight? Or was it something else? If you see this, I appreciate your answers! Thanks!
por
yes I replaced the board, and the monitor is currently still in service!
por
Adicionar a sua resposta
Ronnoc Nailli será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 2,406
