Ir para o conteúdo principal
The Fujifilm FinePix A350 is a basic digital point-and-shoot 5.2 megapixel camera featuring 3x optical zoom and 320x240 15 fps movie recording with sound.
Camera isn't emitting sound
I am trying to playback video that I took on my camera but there is no sound coming from it. I have changed the sound settings and it is maxing out the volume. I have no idea how to fix this. There is no other options that involve volume.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Look to see if there is a mute option that is separate from the direct volume control. If not, the internal speaker may be worn down or lost a connection. Luckily, this is relatively easy to re-solder or replace if you have a replacement part available!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Brandon Gray será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 225
