Ir para o conteúdo principal
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Perguntas Visualizar todos
won't vibrate
My phone has stopped vibrating all together, caused by a drop possibly. I have read that if you smack it on the back corner it will work again . . . not for me. Is it the vibration motor that has gone out? If so, what part do i need in order to fix it?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Here is the part you need, you need to replace the whole headphone jacks, which includes the vibrator. There you will find links to the step-by-step installation guide and everything else you need.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you!
Does it matter which part number i get?
por
I don't believe so
por
Adicionar a sua resposta
Pat será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,545
