Ir para o conteúdo principal
Pergunta encerrada
Won't work unless using power cord.
I have had the Apple Genius look at my computer. My Mac Book Pro (2015) only works when using power cord. When I plug it in it is green for 2 seconds and then turns orange. The battery does not charge. I was told that I needed to spend $1,632 to have the problem fixed. I am saving my money.
This was a year ago. My battery has drained to 34% but when plugged in still works. I am interested in knowing what happens when the battery drains to ZERO? Will my Mac still work if plugged in to electrical outlet? This is my biggest concern.
Thank you in advance to anyone that can answer this question for me. I know little about computers and can deal with it only working when plugged. But what happens when battery drains to zero?
Fixed income grandma
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Can you install this app: coconutBattery and post a screenshot of what it shows you. Try it with the power adapter plugged in and again not.
por
What currency are you using?
por
I agree $1,632 US dollars is way to much!
por
Adicionar um comentário
1 resposta
Solução escolhida
Yes, your mac will continue to operate while plugged in even if there is no battery installed at all.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 60
