Ir para o conteúdo principal
Released in August 2014, the Lenovo Y50-70 Touch is part of the Lenovo's Y series of laptops. Equipped with a dedicated graphics card and a 15.6" touch screen, the Y50-70 Touch is specialized for gaming.
34 Perguntas Visualizar todos
Why does my mouse pad buttons only work in certain areas?
When I press the buttons on the mouse pad, it only reacts in approximately the red cricles (se image). When I press the bottom/edge area, it doesn't seem to register anything. Is it just the build? Or can I maybe fix it some how?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
Hi,
Have you checked the options available in Settings > Devices > Mouse and Touchpad to see if any will resolve your problem?
There is also this link will may be of some help.
http://www.digitalcitizen.life/how-confi...
Esta resposta foi útil?
Pontuação 1
2 comentários:
It seems I have a normal touchpad, and so I can't change anything else than the delay time. I tried that, but to no use unfortunately. However thanks for the suggestion :-)
por
Hi @mad667nus
Here is a link to the service manual for your laptop. if you feel like opening your laptop to investigate your touchpad this will help you. https://download.lenovo.com/consumer/mob...
This is the part number for the touchpad. 5C10F78862 (scroll to p.96) If you wish to find suppliers for a replacement just 'google the part number only. If you add extra info like Lenovo or touchpad it is more difficult to find.
por
Adicionar a sua resposta
Magnus será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 17
Duração total: 2,122
