Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
621 Perguntas Visualizar todos
MacBook expired. data is on ssd but blocked by file vault
Hallo,
I have a macbook that expired. The data is still on the ssd. I want to recover the data from the ssd with a reader but file vault is blocking me with this. Is there a way to fool file vault or to turn it of?
Kind regards,
Sander
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
You have to know the password. FileVault is not just a lock, it actually encrypts everything on the drive.
Esta resposta foi útil?
Pontuação 3
1 comentário:
I have the password from it. But the problem is the macbook died. So somebody build an installation with a reader in it to read out the ssd. The ssd still works because the computer detects it and says there is data on but it is not possible to pick it up because Filevault is blocking it.
por
Open up Disk utility to unlock FileVault encrypted SSD using the password so you can copy off the SSD's content to a fresh drive. You'll need to leave the SSD in the system or use a special USB case made by OWC: OWC Envoy - USB 3.0 MacBook Air SSD Case and access to another drive to copy the contents to.
Pontuação 0
http://forums.macrumors.com/threads/clon...
Pontuação -1
Adicionar a sua resposta
hajabusa1996 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 248
